Results 1 to 6 of 6
Thread: Water leaking around injector
    May 2008
    USA
    72
    Default Water leaking around injector
    955 12a3314 I have water leaking around the top of number two injector. I search the site and found this is probably the pre-combustion chamber. My question is what special tools will I need to do this? Is there any tricks that I need to know.
    Faunsdale, AL USA
    1,779
    One piece or two piece chamber?
    The two piece chamber has the skinny PC chamber and a "retainer" shaped like a doughnut around the top which is removable separately for resealing. There is a set of tools to remove and install the retainer while leaving the chamber screwed into the head. Look down inside the chamber after removing the injector and you should see two size threads inside the opening if it's a 2 piece style.
    The one piece chambers have to be completely unscrewed from the head to replace the o-ring around the top. You would want to replace the copper seals at the base of the chamber at the same time. There would be only one thread inside the chamber after you remove the injector. The one piece chambers tend to stick up a bit out of the to head surface compared to the retainer of the 2 piece style.
    D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare time
    Default Leak
    Your leak no doubt is the "O: ring seal around the top of it so yes it will have to be removed to install a new one.Use soap or the white Lubra-Plate grease, nothing with oil base on it so it slips in easily. Coat the seal and the head surface with it.All the years at the Cat dealer we never used anything but the Lubra-Plate. It looks about like Ponds Cold Cream.
    Liberty, NC.
    1,684
    SJ, i am glad to see that you know what pond cold cream looks like....haha
    Erik Christenbury
    Cat List: More than some, less than others
    http://www.chriscomachinery.com/ACMOChapter12.htm
    Default Cream
    Kid, I really meant to say Noxzema but I guess they are about the same looking.This is no joke but a Dr. assistant gave me advice for hemorrhoids (piles) and that is the Noxzema and I have used it for years on mine when they come down and in just a little bit it shrinks them back and takes the smartness (soreness) out of them.
    Jun 2008
    Marion, NY
    149
    Hey Bowtieih, in addition to the Noxema, you will need the special tools for removal and re-installation. There has been a great deal of discussion about this subject on this forum lately which you should read up on before you get into the job. There is a set of removal tools for sale on ebay right now. The ebay number is 380234992345. Good luck with your project! John
  1. No. 44 Hydraulic Control leaking on D2
    By Arthropod in forum DISCUSSION
    Last Post: 01-24-2009, 04:56 PM
  2. D2 Leaking oil cooler
    By D2Redsetter in forum DISCUSSION
    Last Post: 12-09-2008, 10:17 PM
  3. Leaking Gasoline Valve
    By C.J. in forum DISCUSSION
    Last Post: 04-29-2008, 07:48 PM
  4. Leaking injector pumps
    By railroadjoe220 in forum DISCUSSION
    Last Post: 10-13-2007, 10:46 AM
  5. 955H Water Leaking Around Injector
    By ekasl in forum DISCUSSION
    Last Post: 04-17-2007, 06:54 PM
