cat 22
have fooled with oliver crawlers most of my life and have tons of parts sources but,i have bought a decent cat 22 that has shot pins, bushings and sprockets.i have no source for parts or dont know whats available.otherwise pretty good shape. needing alittle information.are pins and bushings available now?and if not are there any modern substitute of tracks with same pin and bushing diameter and pitch?thanks
22 Tracks
I have not tried loking for pins and bushes myself , But I was talking to a chap a couple of weeks ago and he had just fitted new D3 track chains to his . He had to bush the links to take the smaller Bolts.1/2" down to 7/16". Sprockets and rollers you should pick-up S/H . PV15 and 8C20 are the same . Welcome to Cat World and and good luck . LJ
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
