Thread: Catman Needs Help on a RD4 4G
    CATLAND
    335
    Default Catman Needs Help on a RD4 4G
    I am busy working on 5 cat 30's at present, and I have a Tailseat RD4 4G 1936/37 taking up room in the Catcave, the RD4 is one from the Woodlands Collection and has always been barn stored, I cannot put this cat outside under a sheet, its spent all its life indoors warm, Its present owner is Snr Catman. we have decided to get the RD4 Tailseat out of the Cat-Cave, to free up spare, and get her out at shows restored by this coming may I get some needed Space in my Shop.
    I need some help, This project has Jumped the Query of Restoration Jobs, I dont have a Parts book for an RD4 4G 1936/37?? , Is the engine a Wet Liner Motor ?? if so Can I get Cylinder Sealing Rings Etc ???? the cat looks good, but I would perfer to strip her down and check bearing / gears in tranny/ finals, and check the engines, I could use a Good Parts Pony Motor ???, the Pony on the cat has been welded from frost cranking, which normally indicates cylinder bore Ovality from the welding process etc.
    Any Photos and Scans from any Cat Sales Docs on the Tailseat RD4 4G would be usefull.
    Catman
    devon uk
    429
    Default Rd4
    Hi Catman,
    I expect someone will turn up with a parts book, it is a wet liner motor, seals are still available. It is a D4400, the same as the 7J and 2T engines apart from some changes to the governor. There was very little change in the transmission right up to the 5T series as far as the layout is concerned but ensure you use the right book for ordering parts as Cat had a habit of making updates through each serial number range. early machines had a straight cut bevel gear while later ones had helical cut etc.
  1. Remanufactured manifold from Catman
    By djcat in forum DISCUSSION
    Last Post: 01-22-2011, 12:29 PM
  2. Catman on YOU TUBE
    By Catman in forum DISCUSSION
    Last Post: 01-01-2010, 01:26 PM
  3. CATMAN ON T.V. I need some help
    Last Post: 01-01-2010, 10:24 AM
  4. Looking for Catman
    By Cat-Iron in forum DISCUSSION
    Last Post: 08-25-2009, 12:28 PM
  5. Catman in Tear Down Mode
    Last Post: 08-06-2009, 04:12 PM
