Thread: Late Model Caterpillar Equipment at work
    Pennsylvania
    281
    Default Late Model Caterpillar Equipment at work
    Here are some pics from work today. Cat and Cat powered equipment. Work is being done to construct a new Runway for an airport. The caterpillar 365 is loading 6 40 ton rock trucks w/tailgates and some smaller volvo rock trucks. Drills are for blastholes to break rock with explosives. The haul from the cut to the fill is pretty great (close to a mile at times). Trucks max out at 32 miles per hour loaded!
    Catmatt
    Phila,pa
    357
    Matt,which airport is this at,and who's the contractor.Mike
  1. Late model D25U fuel line
    By Cysco in forum DISCUSSION
    Last Post: 10-29-2009, 07:12 PM
  2. Seeking Late model D2 Clutch collar
    By Dunefanatic in forum DISCUSSION
    Last Post: 12-02-2008, 04:17 PM
  3. Late Model D2 Spring Question
    By compressor in forum DISCUSSION
    Last Post: 10-13-2008, 07:02 PM
  4. late model d2 radaitor
    By miked238 in forum DISCUSSION
    Last Post: 08-09-2007, 11:16 AM
  5. Need Help, late model D2 cooling parts list
    By Steve A in forum DISCUSSION
    Last Post: 11-28-2006, 08:56 PM
