Results 1 to 10 of 10
Thread: part numbers please
    Jun 2007
    canterbury new zealand
    80
    Default part numbers please
    hi,
    i don't have parts books for my R4 or direct electric start D2...
    can anyone give me the part numbers for the following:
    24 volt D2 generator
    R4 hot/cold selector (the one on the dash)
    R4 top radiator pipe (cast- it also acts as the top mount).
    thanks, folks.
    peter
    Chicago
    978
    Kiwi, for the late model D2, my book shows 5H772 for the generator assembly. It also shows 5H1957 for later years. Both ar 24 volt, 18 amp.
    Napa Valley - Newville CA
    835
    Top Pipe 4B3295 Lever 9A9812 My R4 book dosnt show the 24v generator but they are all the same you just gotta get the right gear 26 tooth
    Jun 2007
    80
    that's a great help.
    thanks.
    peter
    Quote Originally Posted by kiwicats View Post
    hi,
    thanks, folks.
    peter
    7,043
    Here is the parts breakdown for the correct 24v generator. Uses the 20T drive gear we already are working on.
    Does not seem to be a lot of applications but does show up on the #12 graders as well. Does interchange with the 8H1957 also found on graders.
    Also should be matched to a 4H7946 or 6H9406 voltage regulator.
    Jun 2007
    80
    tks om.
    leaving for seattle tomorrow night...
    peter.
    7,043
    How long will you be in Seattle.....looking to ship parts there tomorrow or Friday.
    They will be in a flat rate USPS box @ $14.50.
    7,043
    Parts went to post office today....I'm told they should be in Seattle Monday or Tuesday.
    835
    OM what am I missing here. How do you use a 20t gear in a 26t hole?
    7,043
    My eyes probably aren't much better but all the idler gears for the late D2 (6v or 24v) are a 4F3764 - 25 tooth gear
  1. Cat 22 part numbers
    By R4pat in forum DISCUSSION
    Last Post: 03-14-2010, 08:08 PM
  2. Need Part Numbers
    By Frank L. Gross in forum DISCUSSION
    Last Post: 06-22-2009, 12:49 AM
  3. Part Numbers for A D-6 5R
    By bboaz in forum DISCUSSION
    Last Post: 07-14-2007, 04:53 PM
  4. D2 part numbers
    By Andy.s in forum DISCUSSION
    Last Post: 06-15-2007, 09:33 PM
  5. Part Numbers For D2/3J
    By Dozerman51 in forum DISCUSSION
    Last Post: 12-19-2006, 08:43 PM
