Thread: L/pl 20 Steering Levers.
    Sep 2009
    Maclagan Qld Australia
    10
    Default L/pl 20 Steering Levers.
    Need help, does anyone know how to remove the steering levers easily on a top seat 20 serial no L854.
    Thanks for any ideas.
    portland victoria australia
    866
    Exclamation levers
    hello sammysourous,i don't know if there is a easy way ,you need to take the cover of oblong opening in front of the seat and undo each side adjusting nuts of each side lever ,not much room in there ,then the nuts around lever plate and then they should slide out as a whole unit .bruce oz
    Sep 2009
    10
    Thanks for that Bruce, i will give that a go.It will much easier to straightn them with them off the tractor as they got pretty bent during transport.
  1. 22 Steering Levers
    By Peter Mercer in forum DISCUSSION
    Last Post: 02-09-2009, 04:39 PM
  2. D2 5U Steering Clutch...
    By Kiwicat in forum DISCUSSION
    Last Post: 02-08-2009, 07:36 AM
  3. Cat 112 main clutch levers
    By johnstarnes in forum DISCUSSION
    Last Post: 09-27-2008, 06:23 AM
  4. D6 Steering
    By newd6 in forum DISCUSSION
    Last Post: 09-21-2008, 02:17 PM
  5. D2 Choke and Throttle Levers
    By novavalleycat in forum DISCUSSION
    Last Post: 01-21-2008, 06:15 AM
