Thread: How to change a D6 9U gearbox seal ?
    netherlands
    111
    Default How to change a D6 9U gearbox seal ?
    Hello , if i look into the parts book , i see that if i wanted to change the seal from the gearbox that i have to pull out the yoke (with a long shaft), and now iam afraid that the gears and rings will fall down .
    Is there a easy way, so that i do not have to open the gearbox?
    Thank You ,
    Gilbert
    7,055
    Not that I know of nor according to the service manual.
  1. D-9 gearing change
    By firpitch in forum DISCUSSION
    Last Post: 05-23-2009, 08:23 PM
  2. Old Magnet, Seal Change Over Numbers
    By King of Obsolete in forum DISCUSSION
    Last Post: 03-09-2009, 08:25 AM
  3. D-8r641 Gearbox
    By HUNTER in forum DISCUSSION
    Last Post: 10-29-2007, 02:44 PM
  4. Water in gearbox
    By Betch in forum DISCUSSION
    Last Post: 10-12-2007, 08:33 PM
  5. First Oil Change
    By Joel59 in forum DISCUSSION
    Last Post: 05-11-2007, 12:50 PM
