22 track removale
from what ive seen heard and know you also have to pull the track links around the master link together a bit to take some of the weight off of the master link pin and sometimes if the links are rusty or dirty or corroded you might have to heat them up with a rosebud head on an oxy.-aceteyelene torch,then get a sledge-hammer and a thick punch and pop that puppy on out of there, also keep a can of WD-40 handy you're gonna need it. i have my own 22 tracks i need to replace real soon so i've done a lot of research and questioning on the subject myself. GOOD-LUCK
Reason: spelling error
1935 Caterpillar
Citrus twenty-two
serial number:2F2204
