Thread: d4400
    Mar 2010
    pasco wa
    5
    d4400
    What is the correct sequence for engaging/disengaging the engine to/from my pony motor with the clutch/brake and pinion lever? Thanks in advance.
    Eastern Oregon
    966
    Open the run/start lever on the main engine to start, this will release compression in the engine Once the pony has started and warmed, move the clutch/brake lever to the left. This will engage the brake, open the throttle on the pony and then raise the pinion lever. Move the clutch/brake lever to the right and the main should begin turning. Let it turn the main engine until the middle of the main's head reaches body temp, then flip the compression lever to run and open the throttle on the main. After the main starts, move the clutch/brake back to the right and shut the gas off, letting the pony die.
  1. d4400
    By dbergair in forum DISCUSSION
    Last Post: 03-17-2010, 12:05 PM
  2. d4400
    Last Post: 03-17-2010, 07:54 AM
  3. D4400 Injector
    By John in Wy in forum DISCUSSION
    Last Post: 06-15-2008, 04:12 PM
  4. D4400 injectors
    By ozdicko in forum DISCUSSION
    Last Post: 02-20-2008, 06:24 PM
