Thread: D4 hydraulic cylinder question
    Chicago
    984
    Default D4 hydraulic cylinder question
    I have a D4-7U with a 4A blade. I removed the hydraulic cylinders the other day for rebuild. When I removed the retainer from the front mount, I noticed the bushing completely missing. As a result, the pin that the ram rests on has excessive wear. I plan on getting a replacement bushing (3F9363) but I would like to replace the pin. My parts book shows a part number 3F9897 for the pin that the ram mounts to, but shows no other attachment pieces. Does this pin screw onto the crank assembly? Is it welded on? Supposing I can find one, I would like to replace the worn pin so I don't waste a good bushing. I just need to know if it is a weld on or bolt on pin.
    Nov 2007
    NW Ohio
    511
    Default D4 Blade
    They are welded on. They have smaller boss that fits into the brace then is welded around the outer edge. I air arced the old ones off and had my machine shop make new ones out of 4140 i think, it was a good wearing steel.
    Chicago
    984
    Thanks R/KG. This helps a lot. I'd rather know ahead of time rather than cutting on the crank and finding out I damaged something. I appreciate the help.
  1. D8 2U tilt cylinder
    By diablo in forum DISCUSSION
    Last Post: 11-18-2009, 03:44 PM
  2. 5u hydraulic pump question
    By cat1952dozer in forum DISCUSSION
    Last Post: 09-07-2009, 02:28 PM
  3. Hydraulic Cylinder Question
    By Chuck C in forum DISCUSSION
    Last Post: 08-19-2009, 07:54 PM
  4. Replies: 0
    Last Post: 10-09-2008, 01:29 PM
  5. #44 hydraulic control question
    Last Post: 02-27-2008, 05:16 PM
