Results 1 to 6 of 6
Thread: Found a machinery sale listing for the West Coast
    Liberty, NC.
    1,685
    Default Found a machinery sale listing for the West Coast
    Not sure if this is top secret or not, but I have never seen this posted on here. You guys on the West Coast are so lucky.
    http://www.irontrader.com/
    Caterpillar 10, 1929, running when parked, original side panels, good sheet metal, painted yellow, hydraulic blade, $4,150; Dale Eisert 916-749-5210 (Loomis CA)
    Caterpillar 10, runs, steers good, has engine side panels, $3000; Bob Smythe 503-257-9615 (Rhododendron OR)
    Caterpillar 10, two parts tractors, $650 each; Bob 503-257-9615 (Sandy OR)
    Caterpillar 15 (small), 7C series, 1932. Excellent running condition, always stored under cover. Picture available, $7500; Melody Hemley 253-853-6438 or cell 360-801-1240 (Port Orchard WA)
    Caterpillar 15, two parts tractors, $650 each; Bob 503-257-9615 (Sandy OR)
    Caterpillar 20, Big 20, have two to restore, $3000 & $2000; Don Chappell 503-397-0152 or cell 503-679-2726 or janc@ados.net (St Helens OR)
    Caterpillar 20/25/28 PTO complete, reduced to $350; Cat 20/25/28 radiator grill, $150; Greg Andrade 510-427-8095 or dunefrk@razzolink.com (San Juan Bautista CA)
    Caterpillar 22 parts: belt pulleys, choice, both loose, complete, metal cast pulley or conventional, $500 each; Cat 22 Zenith K5 Propane carb complete with spare gas Zenith carb, $200; Cat 22 Zenith K5 carbs complete, two carbs, $175; Greg Andrade 510-427-8095 or dunefrk@razzolink.com (San Juan Bautista CA)
    Caterpillar 22 wide gauge top seat with 8' 4 gang disc. Runs good with many new parts, $4000; Wally Adams 408-268-3308 (Morgan Hill CA)
    Caterpillar 22, citrus orchard with Bishop fenders, $2500; Caterpillar 22 engine, very nice, $950; Don Chappell 503-397-0152 or cell 503-679-2726 or janc@ados.net (St Helens OR)
    Caterpillar 22, stuck, $700; Cat 22, rough, $700; Bob 503-257-9615 (Sandy OR)
    Caterpillar 22, wide gauge running tractor. Pretty darn good undercarriage with rails that appear to be 75% or more with beefy sprockets. Grousers are 1.375 to 1.5". Still has original Cat decals viewable on hood and fuel tank. Modest hitch pin wear. Runs 20 psi oil pressure at idle. Think mag needs a rebuild as the tractor runs fine from idle to a bit over half throttle and as you provide more throttle (past half) the tractor starts sputtering. $2750. Can provide pictures; Greg Andrade 510-427-8095 or dunefrk@razzolink.com (San Juan Bautista CA)
    Caterpillar 30 on propane, will run with a little work. Tracks and undercarriage are in very good condition. S/N s9016, has belt pulley on rear. $2500 or offer. Can E-mail photos to serious buyers; Dax Kimmelshue 530-345-4456 or daxandkaren@yahoo.com (Durham CA)
    Caterpillar 30G wide-gauge factory electric start. Tractor runs and drives very well. Tractor has rebuilt top end, great manifolds, rebuilt electric starter. CM4 magneto, lights, factory nose-guard, mushroom air-breather. Very straight tractor which is unrestored. Can provide pictures. $7500 Greg Andrade 510-427-8095 or dunefrk@razzolink.com (San Juan Bautista CA)
    Caterpillar 30G-R4 brand new old stock exhaust manifold with fins. Fabulous shape. Indescribably good, $1500. Can provide pictures; Greg Andrade 510-427-8095 or dunefrk@razzolink.com (San Juan Bautista CA)
    Caterpillar 30G-R4 intake manifold in very good shape (no drop tube), $450. Can provide pictures; Greg Andrade 510-427-8095 or dunefrk@razzolink.com (San Juan Bautista CA)
    Caterpillar 35 diesel, bad final, otherwise good, $2750; Don Chappell 503-397-0152 or cell 503-679-2726 or janc@ados.net (St Helens OR)
    Caterpillar 40 5G gas wide gauge, rare tractor, recent engine work, electric start, good undercarriage, runs & drives very well, new paint & seats, very nice, $9500. Check our web site www.omnitrac.com. Dennis Wilkinson 541-568-4735 or dwilkinson@omnitrac.com (Cove OR)
    Caterpillar 40 diesel, 1935, sn 1725, rear BeGe Unit, 40% undercarriage, ran good when last used 3 years ago. Also Murray Hydraulic Carryall Model M86, $5000 for both, or will split; Larry Alvares 530-824-2693 (Corning CA)
    Caterpillar 50, gas, complete, restorable, $5000; Don Chappell 503-397-0152 or cell 503-679-2726 or janc@ados.net (St Helens OR)
    Erik Christenbury
    Liberty, NC.
    1,685
    Default here is the rest
    Caterpillar 5U wide gauge direct electric start large front idler toolbar dozer. Tractor runs and drives very well. Tractor had the top end gone through this winter with head shaved/trued, all new glow-plugs, All new injector nozzles, new gaskets, new thermostat, new main clutch. $2k in just new parts alone. New hydraulic hoses from factory metal lines to hydraulic rams. Factory PTO with belt pulley attachment. Belly pan (no hook). Tractor starts great hot or cold. Cat 44 single spool front mounted pump. Can provide more pictures. Extremely original. 158XX serial number. $10,000; Greg Andrade 510-427-8095 or dunefrk@razzolink.com (San Juan Bautista CA)
    Caterpillar 60, complete, with blade, runs good, $10000; Don Chappell 503-397-0152 or cell 503-679-2726 or janc@ados.net (St Helens OR)
    Caterpillar 60, have 2, make one, $6000 for both; Don Chappell 503-397-0152 or cell 503-679-2726 or janc@ados.net (St Helens OR)
    Caterpillar 60, sn 4914, very good undercarriage, new rings & valve grind, new fenders, rebuilt vacuum tank, rebuilt carb & mag, ID tags are intact on the rear housing, drives excellent, $16000. Check our web site www.omnitrac.com; Dennis Wilkinson 541-568-4735 or dwilkinson@omnitrac.com (Cove OR)
    Caterpillar cable control, rear model 29, sn 31E, all controls, 2 drive shafts, one from 46A, one from D7E, 2 engine adapters from D6, D7E, nice; Jerry Kirschling 360-951-9777 or grk_2@comcast.net (Rochester WA)
    Caterpillar combine, early '30's, very restorable, $2500; Don Chappell 503-397-0152 or cell 503-679-2726 or janc@ados.net (St Helens OR)
    Caterpillar D-2 5U, very nice, direct electric start, $6750; Don Chappell 503-397-0152 or cell 503-679-2726 or janc@ados.net (St Helens OR)
    Caterpillar D2 belt pulley, $350; Greg Andrade 510-427-8095 or dunefrk@razzolink.com (San Juan Bautista CA)
    Caterpillar D2 J series: has four. One of the tractors are wide gauges and three are standard gauges. Four have the main engines loose. Asking $2500 for all five (actually 3.5 tractors) which is approaching scrap price but Rick is not a supporter of scrapping whole tractors and wants to sell to a party who may put one or more of the tractors to use in a restoration or as parts donors to another restoration; for details Rick Hawksworth 559-658-5711 or dunefrk@razzolink.com (Ahwahnee CA)
    Caterpillar D-4 7J, restorable, $1500; Don Chappell 503-397-0152 or cell 503-679-2726 or janc@ados.net (St Helens OR)
    Caterpillar D4 belt pulley, $350; Greg Andrade 510-427-8095 or dunefrk@razzolink.com (San Juan Bautista CA)
    Caterpillar D4 parts: draw bar $15; fender $10; grill guard $10; sprocket assembly $15; loader bucket $25; Ron Nevins 530-474-3228 or hidcrk@yahoo.com (Shingletown CA)
    Caterpillar D4 parts: draw-bar $15, fender $10, grill guard $10, sprocket assembly $15, loader bucket $ 25; Ron Nevins 530-474-3228 or hidcrk@yahoo.com (Shingletown CA)
    Caterpillar D6 seat tank $45. Good condition, photos available; Ron Nevins 530-474-3228 or hidcrk@yahoo.com (Shingletown CA)
    Caterpillar D6, 1948, sn 8U806. Carco winch, canopy, blade. Running, working Cat, $3500; Chris Carl 425-218-1313 or jdnut@wavecable.com (Camano Island WA)
    Caterpillar D8-14A starting motor trans; Jerry Kirschling 360-951-9777 or grk_2@comcast.net (Rochester WA)
    Caterpillar D8-46A transmission, model #7M825, out of sn 9 to 10 series; Jerry Kirschling 360-951-9777 or 360-273-8389 or grk_2@comcast.net (Rochester WA)
    Caterpillar pads: wide 24" conventional pads for D4/R4/30/28. Rails ok, not special. 64 pads total with tall grouser height and little wear. Slight pitting in some pads as these came from the south, $1500. Can provide pictures; Greg Andrade 510-427-8095 or dunefrk@razzolink.com (San Juan Bautista CA)
    Caterpillar parts: 4S straight blade, complete with hydraulics off D47U, $2750. Canopy for D4, $750; Cat D47U four roller track rails, 95%, has pads, but pads only 50%, D4N winch, complete, very good, $1500; Check our web site www.omnitrac.com; Dennis Wilkinson 541-568-4735 or dwilkinson@omnitrac.com (Cove OR)
    Caterpillar parts: D8 draw bars off D7E and D8-14A; Cat 24 volt generator, belts, reversible fan from 46A, sn 33000; carb off pony motor; generator 6 volt; starter 12 volt for pony motor; Cat track grease gun (volume compressor), book #7H1680 large button fitting; Cat draw bar pin; Jerry Kirschling 360-951-9777 or 360-273-8389 (Rochester WA)
    Caterpillar parts: package D2/R2 guards, hydraulics, belly pan; I am packaging an R2/D2 Belly pan with a tow hook on it with a D2 hard nose-guard AND two cat 44 hydraulic pumps, 2 sets of lines from the pump to the cross-over pipe, two sets of cross-over pipes (fender to fender), two diverter values, one D2 mounting bracket, and one D2 pump to harmonic balancer coupling shaft. I think the pumps will need to be rebuilt. One does not turn currently. More discrete pictures available of the various parts. $1400. Greg Andrade 510-427-8095 or dunefrk@razzolink.com (San Juan Bautista CA)
    Caterpillar RD4, restorable, with tool bar blade, $1750; Don Chappell 503-397-0152 or cell 503-679-2726 or janc@ados.net (St Helens OR)
    Caterpillar straight blade for D25U, complete with Cat hydraulics $2200. One after-market tilt angle blade, complete, for D25J or D25U series $1200. Check our web site www.omnitrac.com. Dennis Wilkinson 541-568-4735 or dwilkinson@omnitrac.com (Cove OR)
    Caterpillar used parts for Cat 10, 15, 20, 22, 30, 40, 60, D2, D4, 2 Ton, D2, D4, JD Lindeman and JD crawlers, some TD6 and TD9 parts. Dozers, canopies, belly pans and winches. Check our web site www.omnitrac.com; Dennis Wilkinson 541-568-4735 or dwilkinson@omnitrac.com (Cove OR)
    Caterpillar/Holt 2-ton sn 76028, good undercarriage, very straight, new paint & seats, original carb, drives very well, $6500. Check our web site www.omnitrac.com; Dennis Wilkinson 541-568-4735 or dwilkinson@omnitrac.com (Cove OR)
    Caterpillar: Large selection of antique caterpillar tractors Cat 10 thru 60, some restored, some ready to restore. Check our web site www.omnitrac.com; Dennis Wilkinson 541-568-4735 or dwilkinson@omnitrac.com (Cove OR)
    Erik Christenbury
    Woodland, CA
    173
    Lucky? You know where Caterpillar came from, right?
    Liberty, NC.
    1,685
    yes i do. i just wish i lived on the west coast soo close to soo many caterpillars
    Erik Christenbury
    7,055
    The stuff may be on the west coast but some of the prices are for another planet
    Oct 2009
    Rockhampton Australia
    71
    Thumb having a good laugh
    The stuff may be on the west coast but some of the prices are for another planet :eek
    Old Magnet thankyou for that , I had been up most of the night working on deadlines and had needed a good laugh
    prices are for another planet !!!!! it hit FUNNY BONE!!!!
    cheers
    Chester
  1. Seeking trucking on the west coast
    By Dunefanatic in forum DISCUSSION
    Last Post: 03-24-2010, 11:07 AM
  2. Machinery websites
    By MARTYN WILLIAMS in forum DISCUSSION
    Last Post: 04-04-2009, 03:21 PM
  3. Trucking West Coast to New England
    By JGC74 in forum DISCUSSION
    Last Post: 09-27-2008, 09:13 PM
  4. Do you know anything about this piece of machinery?
    By gigulz2382 in forum DISCUSSION
    Last Post: 04-28-2008, 04:37 PM
  5. Transport of 16ton crawler to WEST COAST
    By holt 2 ton in forum DISCUSSION
    Last Post: 04-08-2007, 03:42 AM
