Results 1 to 4 of 4
Thread: D2 piston install The sequel
    Mar 2010
    Bainbridge NY
    454
    Default D2 piston install The sequel
    Friends, I just finished installing #4 piston and ring assembly in my D2, as I progressed they seemed to go together easier as I learned the little tricks. Everyone was installed from the bottom end using nothing but hand power to compress the rings, not that difficult!
    Anyway they are torqued to spec, cotterpins installed, I cleaned up the oilpan and installed a new gasket so that will be ready to lift into place in the morning.
    Thanks to all for your advice and encouragement!
    ITS MILLER TIME!!
    Take care Brothers!
    Dennie G
    Southeastern Pennsylvania
    287
    It appears the "behold she runs day" will be very soon.
    My first "behold she runs day" was January 16 2003
    Bill Glenn
    Mar 2010
    Bainbridge NY
    454
    Bill, I thought I was going to hit the "the behold she runs day" late yesterday afternoon which turned into a damn it won't start day. I have appear to have good compression, 15 pounds of fuel pressure. It will puff smoke and act like it wants to start on ether. I didn't spend a lot of time working on it, I didn't have any antifreeze there and didn't want to water it up, I'll pick up some antifreeze , coolant her up and try it later.
    I have to go to Harrisburg PA this afternoon and finish up a basement remodel my son and I are working on so we can get paid. I'll get back into it Wed when I get back.
    see Ya! Dennie G
    Mar 2010
    Bainbridge NY
    454
    Bill, Behold she runs 1100 hrs, April 20,2010 sounds good but I have a lot more work to do on her before she's ready for the field!
    Dennie G
  1. D2 piston install
    By 64farmboy in forum DISCUSSION
    Last Post: 04-17-2010, 06:09 PM
  2. 3J d2 piston rings???
    By Catmandu in forum DISCUSSION
    Last Post: 04-03-2009, 02:32 PM
  3. Steering Clutch Install Update-Link
    By bernie in forum DISCUSSION
    Last Post: 09-28-2008, 08:23 PM
  4. 41 hydrualic unit install
    By Chuck C in forum DISCUSSION
    Last Post: 09-21-2008, 06:19 PM
  5. Pony cam gear install
    By Don in forum DISCUSSION
    Last Post: 07-04-2008, 04:36 PM
