Results 1 to 4 of 4
Thread: RD4 Torgue values
    May 2008
    Rockyford,Alberta, Canada
    6
    Default RD4 Torgue values
    What is recommended torgue for a RD4 cylinder head bolts and also the torgue for the fuel injector hold down clamp bolts ?
    Cumberland Wi
    245
    Here it is . Hope this helps.
    Matt
    Jan 2008
    MELLEN WI
    195
    The injector hold downs nuts don't have a torque. It says in the manual just enough to make it seal. Too much and you can damage the injector.
    May 2008
    6
    Quote Originally Posted by jmvmopar View Post
    Thanks very much for the info.
    Ken
  1. Catman Needs Help on a RD4 4G
    By Catman in forum DISCUSSION
    Last Post: 12-28-2009, 02:31 PM
  2. 2 Ton Engine Bolt Torque Values
    By edb in forum DISCUSSION
    Last Post: 10-28-2008, 06:13 PM
  3. RD4 value
    By jmckee in forum DISCUSSION
    Last Post: 09-21-2008, 09:25 PM
  4. High Compression values
    By Ole H. in forum DISCUSSION
    Last Post: 12-27-2007, 05:13 PM
  5. New (to me) rd4
    By RABBIT2 in forum DISCUSSION
    Last Post: 05-13-2007, 08:54 AM
