Results 1 to 6 of 6
Thread: New D4 owner
    Aug 2009
    WI
    33
    Default New D4 owner
    I am the new owner of a D4, electric start pony motor, pony motor runs good, big motor runs good, under carrage is in good shape. It does need some work and first on the list is a exhaust manifold. As far as identifying it the number stamped on the back is 2T 779 1942-1943? The number on the block lower right 8B2746 is? a part number? Thanks for any info and help
    portland victoria australia
    866
    Default d4
    hello hookblock,info for your d4 below ,if you could post some pic thank you,we like pic ,
    your d4 2T 779 is a 1943 model, 8B2746 is a block part number
    bruce oz
    Liberty, NC.
    1,685
    here are some D4 serial numbers
    http://www.chriscomachinery.com/D4serial.htm
    Erik Christenbury
    Aug 2009
    WI
    33
    Thanks for the help and info. I am looking forward to working on this
    Jan 2008
    MELLEN WI
    195
    That engine is the D4400. Parts are getting pretty scarce for that engine. Gaskets and such aren't a problem, but hard parts like pistons, liners, bearings, etc. are pretty tough to find new but good used are still available.
    Where in WI are you?
    Aug 2009
    WI
    33
    I am about an hour north of madison. Is an exhaust manifold a hard part, because that is first on my list of things to get. Is the 4400 a reliable motor? or should I start freaking out now
  1. New fifteen owner
    By dadawg in forum DISCUSSION
    Last Post: 12-24-2009, 06:18 PM
  2. New old Cat owner
    By agentorange in forum DISCUSSION
    Last Post: 10-18-2009, 06:22 PM
  3. New Cat D2 owner
    By Cysco in forum DISCUSSION
    Last Post: 03-17-2009, 07:40 PM
  4. New Cat Owner
    By Sprucegum in forum DISCUSSION
    Last Post: 03-08-2008, 11:40 AM
  5. Another Happy D2 Owner
    By 196200 in forum DISCUSSION
    Last Post: 04-20-2007, 06:43 AM
