Results 1 to 7 of 7
Thread: 44 hydraulic oil capacity
    Mar 2010
    Bainbridge NY
    454
    Default 44 hydraulic oil capacity
    Can anyone tell me what the oil capacity is for a 44 hydraulic unit?
    The unit, hoses and cyl's have been flushed and are MT
    Dennie
    Jul 2008
    California
    113
    Default 44 Hyd unit
    According to my parts book it says 14 quarts and the 46 unit uses 7 gallons. Quite a differance. Charlie
    Mar 2010
    Bainbridge NY
    454
    Charlie, thanks I'll put in 14 and see how she works
    Dennie
    Dec 2008
    Petaluma
    343
    Ya, my operators book says 3.5 gallons minimum to operate.
    Nothing Like the Smell of DIESEL in the Morning!
    Jul 2008
    California
    113
    Default 44 Hyd unit
    Wouldn't you think the level will drop when you fill the hoses and the cylinders? Ya don't want to hurt anything. Charlie
    Mar 2010
    Bainbridge NY
    454
    For sure the cyl's and hoses will lower the fill level, I picked up a 5 gallon pail, I'll start with the 14 qts, run it to fill the cyl & hoses then add more oil, once it warms up, I can see into the fill tube, If I can see oil in the fill tube when its warm it should be enough oil in the system.
    Dennie
    Jul 2008
    California
    113
    Default 44 Hyd unit
    Well I over filled my D4C and when the fluid got hot it expanded and the blade would not go down on float, I had to force it down with the control. I figured it out before hurting anything. Your right about letting the fluid warm up before finally filling the tank. Good luck. Charlie
