Results 1 to 4 of 4
Thread: Control Handle Grip rejuvenation or repair
    Wichita, KS
    8
    Default Control Handle Grip rejuvenation or repair
    Working on a Twenty that has control handle grips that are kinda pithy. What are some methods for rejuvenating the grips on these early gas tractors? If needed, what material would be used to create new ones?
    Bob
    461
    Bob, they are hard enough you can either use GOOD body filler or epoxy for flexable bumper repair or something like Lord Fusior. The ones on the Twenty I am working on was in good shape exept that had some scratchs and have been painted over. I have repaired many a cracked steering wheel on wheeled tractors using the epoxy first to fill the major cracks and then a fine layer of body filler to give it the finsh coat before prime and painting.
    Terry
    No complaining on titles here.
    ripley ny i4775
    81
    Default control
    The steering and clutch control handles are a common part to a lot of newer tractors and are avaible from cat. The old ones are very sharp on the tip of the metal in side of the composition handle and have caused nasty cuts in hands. Ron Meeder
    Lansing,Mi suburbs
    526
    BobD
    These are available from Jim Zimmerman, I think I last paid $8 each
  1. Cat Twenty hand crank handle
    By ErnieinTucson in forum DISCUSSION
    Last Post: 01-28-2009, 10:05 AM
  2. cat 28 starting crank handle
    By miked238 in forum DISCUSSION
    Last Post: 09-03-2008, 06:05 PM
  3. cable control on d6
    By 2HIGHTEN in forum DISCUSSION
    Last Post: 06-28-2008, 08:50 PM
  4. #44 control ???'s
    By quinq in forum DISCUSSION
    Last Post: 10-03-2007, 07:22 AM
  5. No 25 CCU Query - Handle & Rod Arrangement and D6 9U update
    By David Wills Cat 60 in forum DISCUSSION
    Last Post: 05-24-2007, 08:47 AM
