Two Ton question
Two Ton question
Showing 1 to 9 of 9 results
ibrich
Send a private message to ibrich
How do I check the level of the engine oil on a Two Ton. The is a cap at the end of the shaft that turns the water pump and the mag. I assume that is to add oil but I can't find a dip stick. Are there any Two Ton owners that can help.
Thanks,
Rich
Tue, Nov 13, 2012 4:06 AM
mudgecko
Send a private message to mudgecko
ibrich, there is no dipstick on the 2 ton, but you check the oil level by opening a drain tap on the lower left hand side of the engine and when the oil come's out of the tap is the correct oil level.
Gilbert.
Tue, Nov 13, 2012 4:14 AM
Reply to mudgecko:
Gilbert.
Thats a heavy question!!! lol
7upuller
Hey Rome,
You crack me up.
Tue, Nov 13, 2012 4:24 AM
mudgecko
Reply to 7upuller:
Hey Rome,
You crack me up.
Never the less, it is a valid question for someone who is unfamiliar with the tractor!
Gilbert.
Tue, Nov 13, 2012 7:36 AM
Reply to mudgecko:
Gilbert.
Yes yes yes just some humor.😆
Tue, Nov 13, 2012 8:58 AM
ibrich
Reply to mudgecko:
Gilbert.
[quote="mudgecko"]ibrich, there is no dipstick on the 2 ton, but you check the oil level by opening a drain tap on the lower left hand side of the engine and when the oil come's out of the tap is the correct oil level.
Gilbert.[/quote]
Thank you Gilbert for the information.
Rich
Tue, Nov 13, 2012 9:16 AM
Mike Meyer
Thank you received: 5
Reply to ibrich:
Gilbert.[/quote]
Rich
[quote="ibrich"]Thank you Gilbert for the information.
Rich[/quote]
Originally there were 2 drain taps on the left side of the sump, but most / many 2 Tons just have 2 threaded plugs in there now and you just need to make sure your oil level is between the 2 plugs, and yes, fill the oil through that large cap just in front of the water pump. The transmission and final drives uses the same oil as the motor, usually a straight 30W or 40W low detergent oil.
Good luck
Mike
Tue, Nov 13, 2012 5:53 PM
ianoz
Reply to Mike Meyer:
Rich[/quote]
Good luck
Mike
I was Told ,The Idea of the two level bungs was ,Because of fuel diluting the oil . At the end of each day ,Drain the oil out to the low level , then top back up to the high level with fresh oil .
Tue, Nov 13, 2012 7:52 PM
Jack
Reply to ianoz:
I was told that you drained off the excess in the morning. The distillate or kerosine would rise to the top over the engine oil after it set for a while. John Deeres had just one level tap; you drained it down to the "full" level.
I never ran distillate or kerosine, did run some stove oil many years ago. I can't recall that the oil level came up all that much. I did break the heads on two engines. The heavy fuel hits awfully hard and has to run hot. Don't do it in you beloved old machine!
Wed, Nov 14, 2012 10:23 AM
