D-2 steering clutch adjustment
Showing 1 to 10 of 10 results
sr4440
Send a private message to sr4440
Feeling a little retarded here.
Where do you adjust the steering clutches on a 5J orchard model?
Can't seem to find it.
Scott
Thu, Jan 10, 2013 4:24 AM
Under the seat, remove cross plate cover above steering clutch housing.
Thu, Jan 10, 2013 5:18 AM
Doesn't an Orchard have a low slung seat off the back?
In that case the metal plate on the transmission (normally under the seat) would possibly be under the steering lever bracket mounts as they should be moved rearward to accomadate the lower seat?
Thu, Jan 10, 2013 6:09 AM
rotorbob
Send a private message to rotorbob
Reply to drujinin:
on a tail seat 5J D2 the steel plate is under the fuel tank .
Thu, Jan 10, 2013 8:29 AM
Steve A
Reply to rotorbob:
This is sounding harder than it needs to be, The cover is imeadiatley behind the stearing levers. Typically just ahead of a seat fuel tank. Its under a flate plate cover that held down with 6 or 8 ---3/8 bolts. The cover measures about 5 x 10 inches If you have a PTO this plate will be removed to install the PTO shifter.
Thu, Jan 10, 2013 7:27 PM
Reply to Steve A:
I looked this morning in the D2/R2 book I have and apparently the low seat I was thinking of doesn't exist on these tractors.
SO rome and steve are correct!
Thu, Jan 10, 2013 9:15 PM
sr4440
Reply to drujinin:
Thanks for the replies everyone.
After looking again yesterday I think Rotorbob has to be right.
There is no plate like the top seat models.
There is a large plate under the fuel tank that I think is also the top cover to the transmission.
You must have to access them through there.
Fri, Jan 11, 2013 7:15 PM
chriscokid
Reply to sr4440:
maybe this will help:
It is from Form 10430-2 operators instructions for 3J1-8600 and 5J1-10561 D2
Fri, Jan 11, 2013 7:44 PM
Mike Walsh
Reply to chriscokid:
Your access cover does not change between a top seat and a tail seat. However, like Bob said, the access cover has a fuel tank sitting on top of it now that the seat and sheet metal have been reconfigured. If you blow out the dirt, leaves and twigs under the tank, you should be able to see where you're going. Now is a good time to pull your hood and fuel tank and repair everything that has been neglected.
Sat, Jan 12, 2013 12:11 AM
Reply to Mike Walsh:
So I went to Vintage Crawlers or something like that and found this photo.
There is indeed a "Tailseat" model, which I thought I was sure of the first post I made.
Then I checked a book that kept showing "Orchard " models but apparently they were standard models with orchard fenders.
I new the levers had to be moved back but in my mind couldn't "see/visualize" the fuel tank being mounted as rotorbob stated.
Well here it is!
Sat, Jan 12, 2013 4:25 AM
Reply to drujinin:
Well here it is!
lol Ya Duh,under the tank i was thinking of the standard tractor, looking under the seat you wouldnt find much lol ! some i think did have a fender mounted fuel tank. then the cover would be easy to get to.
Sat, Jan 12, 2013 5:31 AM
