D8 14a cable, what to use and where to buy?
Showing 1 to 7 of 7 results
reb
Send a private message to reb
I need to replace the cable on my D8. The manual calls for 1/2 inch 6x9 filler wire, right Lang lay, independent wire rope center,preformed, improved plow steel type. Im not sure where to get it. A lot has changed since 1956, is this still the best cable to use for this application? I called fastenal and the closest thing they had was 6x19 ips iwrc. Thanks, Ross/Nebraska
[img]https://lh5.googleusercontent.com/-1gss6yhvwmE/UescOFFdLNI/AAAAAAAAAf0/AsuTUg7ENFU/s800/20130720_181914.jpg?gl=US[/img]
Mon, Jul 22, 2013 9:20 PM
Thank you received: 22
That may be as close as your going to get but I'd try contacting a company that specializes in wire rope. Out here I do business with West Coast Wire Rope (www.wcwr.com)
Mon, Jul 22, 2013 9:32 PM
Old 3T lover
I used to get a lot of good used cable off of cranes that hung steel. Also used cable from elevators....they have to change the cables out if they show any wear.
It's usually not the proper cable but if it's dirt cheap and last almost as long, what the heck.
Tue, Jul 23, 2013 2:37 AM
Reply to Old 3T lover:
I'd pass on the elevator rope, they usually have a fiber rope center.
Tue, Jul 23, 2013 7:30 AM
hellsgate_666
Send a private message to hellsgate_666
could not understand how to start my own thread have a D8 2u
dont know what year it is the only numbers i could find on it was 2u21809 i am trying to remove the steering clutch got the breaks off of it and every thing else but the drum with the clutchs any help we would be greatfull for
Tue, Jul 23, 2013 9:35 AM
Reply to hellsgate_666:
Thats a 1953 model, production ending at s/n 2U23,537 that same year.
If your in that deep you better get some manuals and study up.
The entire cross shaft assembly, both steering clutches and bevel gear are removed as an assembly for repairs, usually the brake bands are left in place and removed as part of the assembly.
Tue, Jul 23, 2013 10:39 AM
reb
ebay is your friend. Manuals are usually available. There are manuals for parts, owners and light maintenence, and a service manual which has in depth info on repairs.
Tue, Jul 23, 2013 6:47 PM
old-iron-habit
Reply to reb:
I agree with 3T. Stop by a local contractor that has cranes. If they don't have cable to give away they will certainly know the local chain and cable supplier.
Tue, Jul 23, 2013 10:42 PM
