D2 direct start , question on water heater for startup
Showing 1 to 6 of 6 results
mabc
Send a private message to mabc
I,ve transitioned to direct start and want to use a heater to help with startup in cooler weather.
I see 2 plugs in the piping that connect engine to the radiator. Are these what I want to use for an inline
Heater? I still want to play with my cat this winter and need to use it to help me scrap out a ditch that
I am cleaning out for my father in law. Plus, I want to use it for snow removal if we get a big one. Thanks for your help and God bless direct start, I love it...
Thu, Nov 21, 2013 2:58 AM
Thank you received: 22
Here is one configuration that should work ok although a connection furthur back on the engine (maybe to block drain) might be better.
Thu, Nov 21, 2013 4:30 AM
There was a Thread on this last winter with lots of great ideas! Unfortunately there is no easy way to install a block heater on a D2. The general concesus is that OM's idea is about the easiest way.Try the SEARCH function in the upper right hand corner of your screen for more Info.
Thu, Nov 21, 2013 7:56 PM
AlaskaDave
Send a private message to AlaskaDave
Yes,OM is correct. The block drain is the preferred location for the lower hose attachment, returning to the position shown in pic for the upper hose. As shown in pic you lose percolation throughout the block which is where the heat is needed. The perc heater must be mounted low enough below the block drain attachment to remain filled with coolant at all times to prevent an airlock and heating element failure. Dave
Thu, Nov 21, 2013 7:58 PM
yancy44 mag
Send a private message to yancy44 mag
Reply to AlaskaDave:
the place is the best but i never stand my block heaters up i make sure that they are laying down and you can make a nice pad with a guard so if you ge a wild stray stick it will not knock off your block heater as well as not making the lower pipe stick closer to the block so she does not get snagged as well i use frame clamp from napa or i order my stuff from a industrial fastener place so I do not have to run to town I have my shop budget so I can buy things like that wire ends and such you buy a bag of a 100 its a lot cheaper and you can use your pan bolts just need longer ones works great i hop this help you in the mounting of your pump also i use a gear box plug heater helps keep your oil ready to go you do not have to leave it plugged👍 in but i do its nice to get on and go
Thu, Nov 21, 2013 10:26 PM
Reply to yancy44 mag:
I got to thinking that if you switched to Direct Start, then you probably also removed your Pony to have a place to put the Batteries? There should be the water connect port on the top back of the block for the Pony which you would have blocked off. What about going in with the outlet of your heater, then finding a low spot at the front to get the cold water from?
Thu, Nov 21, 2013 11:39 PM
1S1K
Send a private message to 1S1K
Reply to drujinin:
If you mounted batteries in place of the pony you could raise them up and use the original coolant routing plan but put a heater/water circulation pump in place of the pony. I saw one in the northern tool catalog for around $60. Cold side would be the bell housing. Good luck.
Fri, Nov 22, 2013 12:10 PM
