D4 7U Exhaust noise and lack of power
Showing 1 to 10 of 13 results
1S1K
Send a private message to 1S1K
Hi all,
I have a D4 7U18212, has a slight misfire it seems, can't feel it but I can hear a distinct pop noise from the straight pipe exhaust. If I kill 1 injector at a time it goes away when I get to number 3 and comes right back as soon as i tighten the injector line. I also feel like it is down on power, it will smoke slightly if lugged down in 5th gear but doesn't really seem to smoke at all otherwise except when cold, the fuel pressure gauge reads normal at high idle but I can't see it when operating the machine. I was thinking of checking the head torque and valve lash hoping maybe #3 exhaust lash is too tight causing the combustion event to leak slightly and be heard in the exhaust. It was slobbering oil from the exhaust badly but the thermostat was stuck open, after replacement it has gotten a lot better but still does it some if it idles a lot. If the valve lash is correct the next step would be pull the head to do a valve job right? Or am I missing something? Any thoughts on piston/ring condition, or how to judge, hour meter shows 14500 and still works. Thanks all.
Tue, Jan 14, 2014 11:27 AM
Thank you received: 39
Check valve lash first.
Could be the #3 injector is not functioning properly. Try moving it to another cylinder and see if the same results occur.
If nothing changes then it's head pulling time.
Tue, Jan 14, 2014 12:03 PM
Check the injection pump lifter heights. They should be 1.736" at TDC Have to remove pumps and use a depth micrometer. Clean area around pumps very good before removal. Engine service manual shows the procedure for setting lifters.
Tue, Jan 14, 2014 8:34 PM
1S1K
So I pulled the valve cover and adjusted the valves with it hot, it does sounds better but still has a slight noise from the exhaust, I think I might pull the exhaust manifold to look at the valves/cylinders with my borescope. Any other thoughts on the lack of power, it hardly smokes at all when lugged down in 5th gear. I saw the post about checking the injector pump heights and possibly fuel filters, I have not had time to check those yet. I'm just wondering if I should check anything else while it is apart. I have ordered an engine/tractor manual and parts manuals, they just haven't arrived yet, thanks for the input.
Mon, Jan 20, 2014 1:07 AM
mrsmackpaul
Reply to 1S1K:
mate I am no expert but I don't think you will be able to check bores or cylinders with bore scope maybe if you gave it a compression test if you can get access to a compression tester for diesel "much higher PSI than a petrol one" it would tell you the difference between cylinders and if its the valves or rings I have borrowed a comp tester from our local diesel injector man before so this might be an option were you live ? If you do pull the exhaust manifold off the ports might tell a lot of the story before going any further hope this helps seeya
Paul
Mon, Jan 20, 2014 3:15 AM
Inter674
I agree with this advice. I had the same problem and adjusted the lift height on No3 which was slightly out and the exhaust beat improved. Mind you I think these engine can produce a slight off beat when idling anyway - perhaps something to do with harmonics. After adjusting the pump lifter it was better and reassuringly a person assisting the 'new' owner said he had a D4 7U from new back in the day, and he said that's how they sounded at idle. The new owner had no idea what we were talking about😊
Mon, Jan 20, 2014 4:06 AM
1S1K
Reply to Inter674:
I know I probably sound crazy but it is a distinct popping sound at idle or full throttle, it only goes away when you crack the line for #3. I will check the heights and readjust if needed, any thoughts on increasing power a bit with out going overboard?
Mon, Jan 20, 2014 4:35 AM
Get a depth micrometer and adjust lifters as noted previously. Then evaluate the noise. You may also want to replace or check the injectors since the pressure they crack at affects the timing like the lifter setting, just not as dramatically. Also the spray pattern and quality of the spray will affect the burn in the PC chamber, so again, the injector can easily affect the sound and the performance of the engine.
Note that the lifter you are checking should begin to rise at TDC when you are checking/adjusting it. The flywheel can be installed incorrectly on the crankshaft flange, so it's always possible that the cylinder markings on the flywheel do not correspond to the crankshaft and camshaft timing. Best to make sure that the lifter is the one that's moving before you adjust it. If you go past the TDC mark on the flywheel to confirm the lifter movement, you should back up a good 1//6 turn of the crankshaft and then bring it back to the mark, stopping exactly on it.
Measure twice.........adjust once! If your check doesn't yield a measurement close to what you expect, stop and re-evaluate your procedure. As I said, the flywheel has 6 equally spaced holes, so on a 4 cylinder engine, there are only 2 positions out of 6 possible that will put the flywheel TDC marks in the correct relation to the crankshaft and pistons. And one of the two will have the cylinder numbers wrong!
I believe SJ used to recommend setting the lifter height high to compensate for pump plunger and lifter yoke wear, so you might want to consider that after you look those parts over carefully.
Mon, Jan 20, 2014 8:00 AM
1S1K
Thanks for the input, I'll report back as soon as I can get back to work on it.
Mon, Jan 20, 2014 10:29 AM
Thank you received: 27
Reply to 1S1K:
Spec. length for pump plunger is 2.6575"-2.6577" (Cat recommend to replace at 0.005" worn) when measured for overall length with an accurate micrometer.
Any wear measured on the plunger length can be taken off the lifter setting to raise the lifter yoke to compensate for the wear on the plunger end where it contacts the lifter yoke.
For example, the lifter setting on engine is 1.736" at Top Dead Centre on the respective cylinders firing stroke.
If your plunger measured 0.002" worn then the lifter setting can now be adjusted to 1.734" This new measurement is determined by :- 1.736" minus the 0.002" wear on the Plunger.
If you were to check the Injection Timing, by the Spill Timing method, your actual injection timing should now be back at the Spec. 15 Deg. Before Top Dead Centre.
Hope this helps,
Mon, Jan 20, 2014 3:32 PM
rjh-md
Reply to edb:
Hope this helps,
I think that before I got into checking the lifter setting ,and all the techanial issues .I would buy a new injector nozzel ,and install it in # 3 cylinder or maybe buy a set of 4 and install them ,not knowing how old the other 3 are .A bad nozzel can give all the symtims you described
Tue, Jan 21, 2014 7:56 AM
