Cat 22 Radiator
Cat 22 Radiator
RossM
Send a private message to RossM
Anybody know if you can buy the tank cork gaskets for a 22 & a thermostat
thanks Ross
Sun, Jan 24, 2016 8:47 AM
sr4440
Send a private message to sr4440
I got gaskets form Olsens.
Got a thermostat from CAT.
I think Brewzer might have some original 22 thermostats
Sun, Jan 24, 2016 6:54 PM
Stuss
Send a private message to Stuss
Reply to sr4440:
Hi Ross I fitted a new radiator to my 22 and Used some gasket material from a radiator repair place and it sealed good not leaking. With the thermostat I had a ring machined to fit a universal thermostat into the existing housing, works okay.
Hope this helps
Sun, Jan 24, 2016 8:07 PM
RossM
Reply to Stuss:
Hope this helps
Thanks for the info guys
Mon, Jan 25, 2016 6:39 AM
Mike Meyer
Thank you received: 5
Reply to RossM:
I've used that rubberised cork sheet on my old girls radiator tanks and it has worked well, available at any bearing shop or Repco Store, get your new bolts and washers from your local Cat dealer, they have the best quality at the best price, either black or zinc yellow, sing out if you need the part numbers for the bolts as there are a couple of different lengths used on those radiators, with the thermostats I measured the old one and got on Google to search out a Aussie thermostat website (Dayco??) which lists all the sizes shapes and opening temps, aim for about 170F or 175F on that 22, and get your local store to order it in, the cost was about $35, you can buy them in the USA for about $US7.00-$US9.00 if you check out Fleabay.
I've bought thermostats from my Cat Dealer here though be aware the temp range might be a bit too high for your 22 running on petrol, OK for the diesels at 185F or 190F, I think the idea of a sleeve to carry a modern thermostat is a good one, double check your parts number book on the thermostat as there were several different one's used, if you don't have a Parts Number book yet tell us your tractor serial number or better still the type of upper water manifold you have that goes into the top tank of your radiator, some have a cap at the motor end, the other type does not.
There are a lot of 22's around Oz and many on here have repaired them, so ask questions if needed.
Mike
Mon, Jan 25, 2016 7:56 AM
RossM
Reply to Mike Meyer:
Mike
Thanks for the info Mike,
yes I think machining a sleeve to take a modern thermostat is a good idea , the water manifold does have a cap at the motor end
regards Ross
Tue, Jan 26, 2016 2:01 PM
