water in oil and exhaust
Showing 1 to 6 of 6 results
Cattle237
Send a private message to Cattle237
So how much trouble am I in. Put water in radiator and went to start engine water came out exhaust and now about a gallon in oil pan. This on a old D4 Cat. Any advice would be welcome. Also need to find wrench to remove oil pan plug.
Thanks Barry
Sat, Feb 18, 2017 9:26 PM
Andrew
First suspect would be a precombustion chamber.
Can you start it to check which cylinder is not firing.?
Sat, Feb 18, 2017 9:31 PM
ThomasMueller
Send a private message to ThomasMueller
I've been working on a d4 d-4400 engine that sat under a tree for a while and had the frost plugs rust through allowing a large quantity of water to get into the oil. This is easily checked by removing the rocker cover. You said oil in the exhaust sounds more like precombustion chamber seals or a bad head gasket. Hopefully not the worst possibility of a cracked head/block. What model d4 are you working on?
Thomas
Sat, Feb 18, 2017 9:34 PM
Cattle237
Reply to ThomasMueller:
Thomas
[quote="ThomasMueller"]I've been working on a d4 d-4400 engine that sat under a tree for a while and had the frost plugs rust through allowing a large quantity of water to get into the oil. This is easily checked by removing the rocker cover. You said oil in the exhaust sounds more like precombustion chamber seals or a bad head gasket. Hopefully not the worst possibility of a cracked head/block. What model d4 are you working on?
Thomas[/quote]
7u with a 15097 serial#
Sat, Feb 18, 2017 9:44 PM
Figure out which cylinder is missing by loosening each injector line in turn. The one that affects the idle the least or not at all is your best bet. If you can't or don't want to run it, you can remove the injectors and put compressed air into each cylinder with the piston at TDC of compression stroke. Watch for bubbles in the radiator. Once you have it narrowed down I would remove the precombustion chamber and inspect. If it is rusted out, the other 3 probably are too. New are available. You might just need to replace the seal washers underneath.
Sat, Feb 18, 2017 10:19 PM
d9gdon
[quote="Cattle237"]So how much trouble am I in. Put water in radiator and went to start engine water came out exhaust and now about a gallon in oil pan. This on a old D4 Cat. Any advice would be welcome. Also need to find wrench to remove oil pan plug.
Thanks Barry[/quote]
No wrench needed; find a bolt head that fits the plug and weld a nut onto your bolt. Viola, instant oil plug tool. Doubles as a final drive plug tool.
Sun, Feb 19, 2017 1:06 AM
Cattle237
Reply to d9gdon:
Thanks for all the help and good wrench Idea
Sun, Feb 19, 2017 1:45 AM
