help me ID my track link D4 6U
captainhowdy
Send a private message to captainhowdy
I would like some help identifying the track link on my D4 so i can get the dimensions and estimate the wear limits. i have found the number and cant quite make sense of it if even i am reading it correctly. but here it goes anyway>>> it looks like it says D 2 M is that even a good number? the master link is the split type with the taper plug in the end with a cork, if that helps any
Tue, Jun 27, 2017 11:37 PM
Thank you received: 39
D2M is not a good part number. Should be one of these with part number cast into the side of the link. Add one number to the link part number to make LH and RH links.
Wed, Jun 28, 2017 12:05 AM
captainhowdy
Thanks Magnet!! that info will help very much
Wed, Jun 28, 2017 12:14 AM
captainhowdy
Reply to captainhowdy:
6B 4645 found it. would this be for an early set of links?
Wed, Jun 28, 2017 2:52 AM
gemdozer
The 6b4645 is a link for hurley track d4
Wed, Jun 28, 2017 3:05 AM
captainhowdy
Reply to gemdozer:
what is "hurley track D4" is this an aftermarket track supplier?
Wed, Jun 28, 2017 4:50 AM
captainhowdy
my links new were 3 34/64 rail height new and the rebuild limit is 3 1/4 the throw away is 3 1/8 inches. my actual height is 3 7/16 with 1 inch left on the track adjusters on the first wear cycle before a pin and bushing turn. tractor shows aprox 4300 hours on meter. should be good for how many hours??? guess?? just for fun:wof:
Wed, Jun 28, 2017 4:57 AM
d9gdon
Red sand?...800 hours
Wed, Jun 28, 2017 6:20 AM
Not the earliest. Application is early 7J D4's. Chart progresses from right to left.
Wed, Jun 28, 2017 6:56 AM
