Should be able to get the parts separately.
The 90 degree stem assembly is a 3S8975
The 60 degree stem assembly is a 3S8973
The 45 degree stem assembly is a 3S8972
All use a 3S8606 sleeve.
I believe they are trade size "Group 61" fittings.
I will call Cat parts in the morning and place my order. Thank you for the help.
Here is the complete hose assembly numbers if you want to go that way.
5S5641 (83"), 5S5642 (72.25")
Again thank you. I have the parts book for the tractor but not for the accessories. Thanks.
Info is found in the 141,143,151 & 161 Hydraulic Control s/n 62G7001-up Form UEO70089
