D4 7U fuel question.
Showing 1 to 10 of 13 results
bplunk
Send a private message to bplunk
When the need arises to bleed the fuel injection system of air is doing it thru the fuel injection pump vents the best way or should you use the loosening of the injection line nut? I have the wrench to loosen the pump vents. I know the procedure for bleeding the system just curious on the pump vents. Thank you.
Mon, Oct 29, 2018 7:34 AM
STEPHEN
I generally bleed sequentially all the way from the fuel filter housing to the injection valve.
Mon, Oct 29, 2018 8:30 AM
Reply to STEPHEN:
Vents are the best. Loosening and tightening the lines can over time may damage ferrules on the lines. But later pumps did away with vents, so I could be wrong.
Mon, Oct 29, 2018 8:57 AM
STEPHEN
No, you are right. I caught hell finding a replacement D50 line that was buggered by a hammer mechanic. If you bleed from the line, use an easy touch.
Mon, Oct 29, 2018 11:14 AM
catsilver
Reply to STEPHEN:
The vents easily bleed the air from he fuel gallery from hardly any pressure, leave them open with a full tank and the fuel will run straight through, bleeding at the lines needs the throttle shut off and some pressure at least to lift the non-return valves in the top of the pumps.
Mon, Oct 29, 2018 2:27 PM
GrantJ
Thank you received: 7
This brings to mind my question about my D4 6U. Where can I buy the wrench for the vents? I know my dad had one for his RD4, but I cant find it. Thanks, Grant.
Mon, Nov 5, 2018 10:46 PM
old-iron-habit
Reply to GrantJ:
I bought one not to many years ago at my local Cat dealer. They had one in stock.
Tue, Nov 6, 2018 8:46 AM
Reply to old-iron-habit:
I have the version that goes on a 1/4" ratchet that I use with a 3" extension.
I've posted the part number before, if no one finds it in a SEARCH, I'll get it tonight.
Wed, Nov 7, 2018 7:08 PM
d2gary
Thank you received: 45
Reply to drujinin:
Check the for sale section Harry Brandt has cat tools on ebay
Wed, Nov 7, 2018 9:32 PM
Reply to d2gary:
$9+ dollars for the socket from Cat, 5P2682
Thu, Nov 8, 2018 2:30 AM
catskinner
If you have a CAT salvage yard around or know of one, how about checking there for the little wrench. catskinner
Sun, Nov 11, 2018 10:40 AM
