Mounting a 25 Unit on DD D7E?
Showing 1 to 10 of 18 results
Rd6 plower
Send a private message to Rd6 plower
Do you need to run spacer Plate and what tail shaft do you run is it that same as 2u or 13a?
Wed, Feb 20, 2019 12:12 AM
No spacer plate needed. Any D7D or D7E shaft should work.
Wed, Feb 20, 2019 1:12 AM
Thank you received: 22
Is that for sure, big difference in back end bolt pattern between the D7D and the E.?
Doesn't work looking at towing winch mountings.
Wed, Feb 20, 2019 1:47 AM
Oh thats right Mag! I forgot, my clutch is slipping again, ding dang!
Wed, Feb 20, 2019 4:34 AM
You still may be right, I'm just not sure. Looks like the #25 picks up both the 6 bolt circle of the early D7's as well as the later 8 bolt circle. The two large stud locations at the top look to be the same. It's the rest of the large studs that are used for the towing winch that don't interchange.
Wed, Feb 20, 2019 5:18 AM
As far as shafts, doesn't look like the 2U version would work or at least it is a different part number 4F2019 than the D7d (17A) part number 4F2813.
Wed, Feb 20, 2019 5:51 AM
I was thinking they did fit both but the covers are different.
Wed, Feb 20, 2019 6:05 AM
gemdozer
Thank you received: 12
The rear patern bolts is different for 17a and d7e
Wed, Feb 20, 2019 6:11 AM
Reply to gemdozer:
Don't give up yet. The #25 fits D6 (with adapter), the d7 and the D8. Looks to me like the D7E has the same CCU mounting pattern as the D8. Yes, the covers are different, 6-bolt vs 8-bolt but the #25 looks to accommodate both.
Damned if I can tell, here's the mounting flange of a #29/#127 that would normally go on the D7E DD.
Wed, Feb 20, 2019 6:26 AM
gary in CA
I will add my 2 cents worth.In 1979, so memory is fuzzy.We borrowed a Cat 25 cable unit and a Cat ripper from a neighbor that had a 17A to put on our D7E 47A.The cable unit bolted up fine.We had to have a shaft special made as we could not find one.I also believe we had to take off one lever and even modify the other used, to clear fuel tank
Wed, Feb 20, 2019 7:07 AM
Reply to gary in CA:
I think that solves the mounting hurdle. About the shaft, did you have or try the 17A shaft? Defiantly would have to modify the levers to clear the tank.
Wed, Feb 20, 2019 7:16 AM
