D2-5U main clutch adjustment
Showing 1 to 6 of 6 results
beaver-flat
Send a private message to beaver-flat
I'm trying to adjust the main clutch on my early D2-5U. Following the service manual and pulled out the button but I'm unable to get it to turn to tighten up the clutch. Any suggestions?
Thu, Apr 9, 2020 5:34 AM
Spray with WD40 and tap it around with a long drift and a hammer.
Does the mechanism look rusty?
Thu, Apr 9, 2020 10:12 AM
beaver-flat
no rust but it did sit for 20 years out in the elements.
I'll try tapping it, probably just gummed up.
Thu, Apr 9, 2020 8:17 PM
Reply to beaver-flat:
Put the transmission in gear then try turning it.
Thu, Apr 9, 2020 9:30 PM
beaver-flat
I had the transmission in gear, just couldn't get the spider to turn.
Thu, Apr 9, 2020 10:22 PM
Ok, keep putting rocking it back and forth, try a pry bar too. Make sure pin is all the way out.
Thu, Apr 9, 2020 10:29 PM
Thank you received: 41
Second that - if the pin is a bit rusty, it can sometimes not come all the way out - you can use a feeler gauge to confirm it's clear of the pressure plate. If it's not clear, don't whale on it. Spray it with some stuff, then turn it with your fingers and loosen it up. Once it comes all the way clear, then you can fashion a fork to put behind the knob to hold it open while you adjust
Thu, Apr 9, 2020 10:48 PM
