1942 D4 7j serial number info
3 years 7 months ago #221968
by CatD4Dozer
My D4 is serial number 7J9532w. The "W" is on the tractor and engine serial number tag. I have found no information on what the "w" is for and have not located any information on it. Any information would be appreciated.
Thank you received: 258
3 years 7 months ago #221969
by rax200
Hi CatD4Dozer,
The W usually stands for wide gauge on these early dozers, later on they changed the designation like 6U for narrow and 7U for wide gauge.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
3 years 6 months ago #222470
by ismo.kivimaki
Hi
Can you give me advice where to find serial number in these early D4 tractors. Found tractor which I suppose is maybe 1940 -- 1945 model. Tractor is yellow but original color is army green. It is possible that tractor is old war machine and sold to Finland when army after war was trading surplus machines.
Regards
Ismo
Thank you received: 6
3 years 6 months ago #222471
by Andrew
You won't access the serial no on the rear with that winch fitted .
The rear plate may have been removed to give a flat surface for the winch to bolt to .
However the number should be stamped direct into the rear housing. Visible if you have the winch off.
Also there should be a serial plate on the engine block. Sort of behind the pilot motor clutch controls .
Your tractor looks like a 2T series D4. Fitted with a LePlant Choate bulldozer and hydraulics.
Nice find and good luck with your tractor.
3 years 6 months ago #222472
by ismo.kivimaki
Thanks for information Andrew
I have to work more to find serial nr.
What do you think for right day value for tractor ?
Regards
Ismo
3 years 6 months ago #222478
by Andrew
Ismo.
Value or sale price seems to vary in different parts of the world.
It often stuns me the seemingly cheap prices for tractors in USA. Also the range of rare or unobtainable to us in Australia , tractors in the US.
If you can afford your purchase and enjoy it , Go for it .
Time to create page: 0.148 seconds
