D4 Cat 7U17640 1952
D4 Cat 7U17640 1952
3 years 2 months ago #225252
by Hayhauler44!!
Looking to replace pony motor with electric start. Any information would be very helpful on how to get a kit to do this.
Thank you received: 11
3 years 2 months ago #225282
by Hayhauler44!!
This cat doesn’t have the bell housing your referring to. Can you mount the starter where you engage the pony motor to the fly wheel?
3 years 2 months ago #225300
by nomorejohndeere
You have to drill a hole for the starter in the bellhousing with a hole saw and drill and tap mounting bolt holes. Does your bellhousing not have the machined blank for that?
There have been people mount there own homemade starter engines in place of the pony. Good luck.
Are you going 12v or 24?
Are you in a cold climate?.
If you are you will want a way to warm the engine before using the electric start as your engine does not have glow plugs.
Or add glow plugs.
Some people attach a belt around the pull start pony flywheel and power it with another engine or electric motor. Using the tractors original pony clutch and pinion engagement system.
Or pull start or park at top of a hill.........
D47U
AC HD3
nomore JD1010
nomore IH T340
3 years 2 months ago #225353
by nomorejohndeere
I'm sure I've seen people attach a starter to the pony drive engagement pinion. I think there is a company that makes one.
It's been awhile since I looked at all those possibilities.
Does your machine have a PTO?
D47U
AC HD3
nomore JD1010
nomore IH T340
3 years 2 months ago #225374
by Hayhauler44!!
It has a winch on the back. It’s old but fairly good shape, don’t want to put a lot of money in it. Might just pull to start. Thanks for your help.
3 years 2 months ago #225390
by nomorejohndeere
turn the pto with a tractor to start
roll start works fine just don't run outta fuel or stall in a spot you can't pull out of
I guess you could engage the winch and pull start it like a big lawn mower............
fix pony
D47U
AC HD3
nomore JD1010
nomore IH T340
D4 Cat 7U17640 1952
Time to create page: 0.159 seconds
