pilot motor removal
pilot motor removal
3 years 5 days ago #227669
by Dieselray
Removing pilot motor and replacing with 24 volt starter. D74T. I have removed 11 x 3/8 bolts including the two under pilot clutch housing. The unit is loose however seems to be binding around diesel motor clutch housing. Have I missed something. There are no bolts in the starter transmission
housing.
Any help much appreciated.
Regards
Ray
Fat Dan
Thank you received: 724
3 years 4 days ago #227672
by Dieselray
Found the two culprits. Glad Im not putting the unit back in. Thankyou so much for your help. Ray
Fat Dan
Thank you received: 580
3 years 4 days ago #227679
What are you going to do with the pony Ray? And what's your location?
3 years 3 days ago #227716
by Dieselray
Hi Neil
I am in Queensland Aust. One cylinder was using oil then the 6 volt starter burnt out. There is a guy who sells the conversion who has sold a
lot of units. Decided to go that way.
Ray
3 years 3 days ago #227718
Righto, there might be members in Oz that would like that piece of iron
Thank you received: 196
3 years 3 days ago #227731
by Mike Meyer
Good suggestion Neil, I need a starter motor for a RD6 but I don't think the D7 one will fit sadly, but there might be someone in Oz who could use it even as a parts donor.
3 years 2 days ago #227750
by Dieselray
I cannot believe the location of the bolts holding this pony on to the engine and clutch housing. Thanks to Ol Magnet for the info. I have one bolt
to go. I have cut up spanners to get to the bolt. Ran out of daylight tonite. 10 pound sledge hammer might be the go when it comes out. All good fun
though.
pilot motor removal
