9uD6
9uD6
2 years 11 months ago #227775
by 90212
My friend has a 9uD6 that one steering clutch does not put power to the track..Does the steering clutch come out the top for repair or does he have to remove the final to correct the problem? thank you for the help.
Thank you received: 123
2 years 11 months ago #227787
by AndrewD4678
Steering clutch replacement is a weekend job if you have a backhoe or a chain-fall hoist to do the lifting (of cable unit and clutches). The two cover plates under the fuel tank/seat is where they are located. Remove about 16, 3/8" bolts to get the cover plate off then remove the brake band and use a bottle jack under the grouser cleat at the sprocket to roll the tractor forward enough to get to the bolts holding the steering clutch to the bevel gear shafts flange and final drive pinion flange. When you use the bottle jack under the dozer cleat at the sprocket it won't take much movement to get from one bolt to the next. I pump the jack with my foot so i can watch everything turn. Removing the cable unit makes it much easier but its not necessary. There is a small access plate on the main frame above the final drive held in place with two 3/8" bolts. You'll have to remove it to get to the bolts holding the FD pinion gear flange to the steering clutch.
9uD6
Time to create page: 0.131 seconds
