2 ton serial number location?
kiwicats
Send a private message to kiwicats
hi guys,
other than the brass plate under the seat and on the engine, is the serial number displayed elsewhere (on the 2ton).
the tractor in question is a later model...
thanks.
peter.
2 Ton
10
15
22 (2f,1j)
R4
D2 (3j,5j,4u,5u)
D4 (4g,7j,2t,5t,6u,7u)
Diesel 35
D8 (8r)
Thu, Sep 17, 2009 2:16 PM
84WD10
Send a private message to 84WD10
Hello Peter
I have been told that the 2 Ton's also carry their Serial Number, located, stamped on the lower right hand side of the radiator casting, so that would be worth a try, good luck.
Alan T Lewis
Christchurch
NEW ZEALAND
Fri, Sep 18, 2009 4:34 AM
kiwicats
Reply to 84WD10:
Hello Peter
Alan T Lewis
Christchurch
NEW ZEALAND
tks alan.
will check.
rgds,
pt
2 Ton
10
15
22 (2f,1j)
R4
D2 (3j,5j,4u,5u)
Diesel 35
D8 (8r)
Sat, Sep 19, 2009 4:31 AM
