Oil Grade
Oil Grade
budtoh3zo
Send a private message to budtoh3zo
Im pretty sure the previos owner has the wrong grade of oil in, When it gets hot it starts leaking oil out of the rear main oil seal and a few other spots. I want to drop it out tommorow and change it to the proper grade, what should i put in her? Thanks. Also its 16 quarts right? in a D4 7U
Tue, Aug 24, 2010 6:16 AM
B4D2
Crankcase capacity is 5 gals (20 qts), 15W40 is fine, or straight 30 if you'd like. Canada gets cold, so I'd opt for the 15W40. Someone here suggested 15W30 in the really cold climes. Good luck.
Tue, Aug 24, 2010 9:06 AM
budtoh3zo
Reply to B4D2:
Thanks, i think i will go 15-40 for now, i was thinking 0-40 for winter? whats your thoughts? The coldest i will probibly run it is -20*C
Tue, Aug 24, 2010 11:17 AM
