Need Help with ID of #60 elevating grader power unit
Showing 1 to 10 of 13 results
chriscokid
There is a # 60 Elevating Grader SN K225 that needs some work.
I would like to get it running before the first of Nov. but i need help with the ID of the engine.
Engine SN 6A31, according to the book it shows it as an power unit 1931
It looks like a 28 engine?
I need a manifold, Carb, and Mag.
Any help would be most helpful.
Fri, Sep 24, 2010 4:39 AM
Tom Madden_archive
I believe it is a Cat L or PL 20 power unit.
Fri, Sep 24, 2010 5:03 AM
Kelly
[quote="chriscokid"]There is a # 60 Elevating Grader SN K225 that needs some work.
Any help would be most helpful.[/quote]
chriscokid,
My information show the Caterpillar Sixty elevating Grader of 1931 was basically the same as the Russell 42 Giant but featured a larger 28” diameter plow disk and started with Sn K1. Other information states the engine for the Sixty Elevating Grader was power by the 36 horsepower 4200G (gas) engine.
Kelly
Fri, Sep 24, 2010 7:39 AM
Sasquatch
Thank you received: 5
Reply to Kelly:
chriscokid,
Kelly
I would bet my bottom dollar that this machine was sold at auction near Siren, Wisconsin a couple weeks ago, it looks like an exact twin to the one I saw there. Am I right?😖uspicious:
Fri, Sep 24, 2010 8:17 AM
chriscokid
Reply to Sasquatch:
yes it is the same one.
So... what tractor has a 4200G engine?
Fri, Sep 24, 2010 8:37 AM
Kelly
Reply to chriscokid:
[quote="chriscokid"]yes it is the same one.
So... what tractor has a 4200G engine?[/quote]
4200G was use in the "20"as well as the number 7 (1932-1933) and number 9 (1931-1932) Auto Patrols
Kelly
Fri, Sep 24, 2010 9:15 AM
KCB
Send a private message to KCB
Reply to Kelly:
Kelly
Kelly is correct on the 4200G engine usage. That would be L/PL "20". The engine is 4" bore x 5.5" stroke.
Fri, Sep 24, 2010 9:59 AM
Kelly
Reply to KCB:
Tom is correct as well.
Kelly
Fri, Sep 24, 2010 10:10 AM
terrywelch_archive
Reply to Kelly:
Kelly
Our club has a PL20. I spent many hours working on it. The manifold looks like ours did. Catiron gave us one section of a nice manifold,The other we had spray welded. It does not look that nice , but works.
Did you get the conveyor and or disc with it?
Fri, Sep 24, 2010 10:22 AM
chriscokid
Reply to terrywelch_archive:
it is a complete machine, it does have a broken front axle but not for long.
I do not own the grader but a freind of mine does, I am just helping him to get it going for a show on Nov 5-7. I will post more info about this show in a seperate thread.
If any one has a manifold, carb, and mag that they would like to sell please contact me [email protected]
Thanks for all of your help.
Fri, Sep 24, 2010 7:03 PM
Chad Poe
Send a private message to Chad Poe
Are you planning on having grader running at the show in Carthage.If so i'm looking very forward to see.
Sat, Sep 25, 2010 6:12 PM
