- Thank you received: 733
Ian being a special application crawler it might only have a low volume pump Old Magnet will no doubt be able to check that off your serial number for you
and yes Old Magnet is 100% correct in does the ram or rams hold the scoop or do they drift
some more thoughts maybe being a SA crawler I assume came from the Downs it may have had a flow diverter valve put on for a air seeder and and you need to open that up to increase the oil flow
Paul
You have two hydraulic systems, a high volume low pressure for the scraper and high pressure low volume for the tractor/blade, small leaks which allow the blade or scraper to drop overnight won't make much difference to operation. If the scraper rams are double the volume of the blade rams, their operating speed will be half the blade rams. If a ram is the same length and 1.5 times the diameter of another, its volume is getting close to double. We need more detail of ram dimensions for this question. Meanwhile, do a blocked cylinder test, hold the scraper up with a crane, disconnect the hydraulic lines, if they aren't quick couplers, the lines will need to be blanked off, then let the crane off. If the scraper still creeps down, you can forget any seal or spool leaks in the control valve, the fault is in the ram seals.
Any of that old Cletrac era stuff is going to be low pressure high volume hydraulics like 650 - 1000 psi max. The 98J (special application) with built in hydraulics and designated pump is going to be higher pressure, probably in the 2250 psi range. I don't have the service manual for the 98J, just the parts manual for 98J1591-up.
cat@acmoc.org
- Chris R
- Jason N
