advice needed for Riveting new fenders
Thank you received: 42
3 years 7 months ago #222462
by Steve A
I have the pieces on the way to assemble new fenders for my Cat Sixty. I have done some riveting in the past by heating them and peening with an hammer, not going to do that again. As a kid I did assist my dad a few times driving aluminum rivets in aircraft, my job of course was holding the bucking bar. I would like to buy a suitable air hammer for the 1/4 inch rivets used in Most antique Cat Sheetmetal. My problem is there are many choices in air hammers and little info on what is best suited to drive 1/4 steel rivets. Can anyone offer first hand advice on how you did it or what size air hammer you used. TIA
Thank you received: 582
3 years 7 months ago #222463
Steve, if you don't find any joy here, I bet the steam groups would be able to give you good advice
Steve A
3 years 7 months ago - 3 years 7 months ago #222474
by hfdzl
Steve, I have done a few sets of fenders and seat boxes. I have Chicago Pneumatic 501? It is an antique, but the same as current production. Figure out your grip length. There are several places online to buy solid steel round head rivets from. I made all the tooling out of S7 or 4340/4140. Smaller 3/16 rivets, I buck them up tight and use a hammer. I cherry the bigger rivets with a torch, you have to experiment on a sample piece, so you get the correct result. It does take some time because we don't have the facilities that the factory had.
Good luck, Herb
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
Last edit: 3 years 7 months ago by
hfdzl.
Steve A
Thank you received: 88
3 years 7 months ago #222476
by side-seat
Steve, Just get one of those cheap $10 air chisels and cut one of the bits off, face it in your lathe and use a ball endmill the proper radius of rivet to form the tool. Make a bucking bar out of a big piece of cold finish steel maybe 2x4x1.5" use the same ball mill on the drill press and drill a shallow hole like the tool.
I've riveted thousands of 1/4" rivets on all the CAT sheet metal I've made over the years.
Steve A
3 years 7 months ago #222487
sideseat, any chance you could put up a video of how you rivet? I think it would be very educational for a lot of us.
Thank you received: 196
3 years 4 months ago #224843
by Steve A
I assembled the fenders for the Sixty today, I still need to attach the steps after some more bending. Attached is the Trial fit up, I was happy with the outcome.
edb,
hfdzl
Thank you received: 129
3 years 4 months ago #224844
by Skinner
Fender looks great!
The late George Rankin would bolt the pieces together then remove one bolt at a time and replace with a Rivet. Skinner
Steve A,
Time to create page: 0.202 seconds
