Oil pump suction gasket V-101 0V-0101 4B-8136 D4 2T
Thank you received: 344
3 years 4 months ago #224055
by Deebo
I noticed a hand written note on my PDF copy of the parts catalog for my D4 2T for the gasket on the suction bell for the oil pump. It says 4B-8136 for the gasket V-101 (0V-0101). When I searched for both part nos. on parts.cat.com the old one didn't show and the handwritten one said there's an indirect replacement and to contact dealer. Just wondered if anyone with a Numerical Parts Record could see if there's an updated number? I was going to make a gasket anyway as I've dropped the oil pan to clean and inspect it but now I'm curious to see if there's one available. Thanks!
Thank you received: 258
3 years 4 months ago #224056
by rax200
Hi Deebo,
Try Dana at Florin Tractors he has them, the 4B8136 is the updated part number.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Deebo
3 years 4 months ago #224058
by Deebo
Ok, great, thanks, pity I was in Florin Tractor in October and didn't pick one up.. anyone know the gasket thickness roughly if I make my own?
3 years 4 months ago #224087
by rax200
Hi Deebo,
If I remember right it is cork about 1/16 inch thick. I am not home at the moment so I can't check
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
Deebo
Thank you received: 764
3 years 4 months ago #224090
i have found many part numbers you just need to add a couple of zeros after the first 2 characters to get a match on parts.cat as they have gone to longer part numbers. if you ring a dealer though they dont have a problem using the original numbers.
as for making your own around 12thou would be just fine. if you have it apart just take a piece of the old one with you when you go to get some.
Deebo
Time to create page: 0.161 seconds
