Diesel engine RPM measurement
Thank you received: 49
3 years 3 months ago #224865
by Delta KJ
I have a D2 5U that needs the diesel engine low idle and high end RPM adjusted. Historically, I have set the RPMs by sound, but I want to set them more precisely.
I would appreciate any thoughts on the best way to measure the engine RPMs on such vintage tractors?
Thank you received: 992
Thank you received: 373
3 years 3 months ago #224870
by D4Jim
Use a non-contact tach. I have a Harbor freight one for about $40 that works well. Place a piece of reflective tape on the crank pulley and easy to use.
ACMOC Member 26 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Thank you received: 764
3 years 3 months ago #225151
an optical tachometer is the way to go. not expensive either. the hardest bit is to get the reflective tape to stay on
3 years 3 months ago #225216
by Delta KJ
Thanks for the advice.
I picked up a laser tachometer from Harbor Freight ($40) and it worked perfectly... Should have purchased one fifty years ago LOL!
Thank you received: 580
3 years 3 months ago #225221
You'd need Marty McFly's DeLorean to pull that one off! : )
Time to create page: 0.154 seconds
