3t sprocket repair
3t sprocket repair
3 years 4 months ago #224915
by willitrun
Happy New Year all, question- I'm contemplating replacing the sprocket drive ring on my 3t with a weld-on replacement. My question is how to remove the track frame to allow access to the sprocket. If I take the a-frame brace and the outer axel mount loose can the frame be wiggled off the end of the end of the spring somehow? looks like a daunting task. Thanks
Thank you received: 992
3 years 4 months ago #224916
by Rome K/G
Happy New Year! Yes the frame can be removed if the back end of the tractor is high enough for clearance.
Thank you received: 342
3 years 4 months ago - 3 years 4 months ago #224926
by edb
to remove and refit sprockets in the field without a crane we used to rotate the track to have the master pin at the sprocket and split the track and bar it off the sprocket out of the way.
Proceed to undo the items as you have said and simply jack far enough for the sprocket to clear the track frame the rear of the machine on the side in question and securely block it up, for a rim replacement you could lift the rear less and bar the rear of the frame out/over enough for the rim to be removed and replaced.
Have done them this way--last one was a few years ago on Mike M's RD6.
There is an instruction in the Conservation Bulletins loaded on the site somewhere.
I have a later Special Instruction (SI) that I seem to have mislaid and the loaded copy I lost in a computer crash and cannot get my new laptop to read my backups--sheesh. The SI has same method and data if I recall correctly but may suggest different later specification rods. and/or wire.
www.acmoc.org/bb/crawler-tractors-diesel...ement-d7-d8-tractors
Last edit: 3 years 4 months ago by
edb. Reason: add link
3 years 4 months ago #224930
by willitrun
OK, if I got this right- split the track, unbolt brace and end of axel support from the frame and there should be enough slack in spring perch to drag/ bar the frame out enough to replace the sprocket rim? Thanks
Thank you received: 582
3 years 4 months ago #224933
Eddie, if you have backups you can't read and can't find someone local to help, let me know. We can upload them and get them mounted so you can go through them.
Thank you received: 169
3 years 4 months ago #224937
by josh
Here are the pages from the D7 Servicemen's Reference Book detailing moving the track frame to access the sprocket.
willitrun
3t sprocket repair
Time to create page: 0.158 seconds
