D8 15A blade hydraulics
Thank you received: 584
3 years 5 months ago #224490
Phil, can you clean it with some paint stripper?
Thank you received: 109
3 years 4 months ago #224546
by PhilC
Thanks OM
The CCU's in your pic look the same as the one on mine. Is there much difference between the two?
The tag is corroded and very brittle so I don't think paint stripper will work. I guess it would be worth a try. though.
Thank you received: 737
3 years 4 months ago #224558
The biggest difference with the 54C CCU is the way it mounts to the frame. The mounting flanges are parallel to the tractor main frame where the 27E flanges (ears) are perpendicular to the frame.
3 years 4 months ago #224569
by PhilC
Hello OM
On second inspection the rear of the CCU looks nothing like the one in your pic.
Thank you received: 97
3 years 4 months ago #224586
by kracked1
Phil, that looks like your hydraulic unit. The CCU is the winch setup on the rear of the tractor.
3 years 4 months ago #224604
by PhilC
This tractor has a big hyster winch on the back. No room for a rear CCU.
Looking at the serial tag I can make out the first two numbers and they appear to be 20.
This
auction on Grays
shows a similar unit with a serial of 20D71. Also says it is a #30. I assume it is an foreign (possibly UK) equivalent like the hydraulic unit. With OM's description of the "ears" that would make this unit a 54C equivalent.
3 years 4 months ago #224610
by kracked1
Phil, that is a HCU. A CCU is a cable control unit. TOTALLY different animal. OM is talking about a CCU.
3 years 4 months ago #224614
by PhilC
No those last pics show the rear side of the CCU. It is NOT a hydraulic unit. The tractor in the first post is hydraulic but now we are talking about another tractor that has no hydraulics only a FRONT mounted CCU.
3 years 3 months ago #226127
by PhilC
Hello All
Getting back to the hydraulics on the D8 I was thinking about the fact that they are off an early D8H. This 15A has cracked both chassis rails near the final drive housings. The left side has been repaired but the right side is still broken.
My thoughts are if the hydrualics are off a D8H then maybe the hydraulic pressure is too high for the 15A., Does anyone know what the pressure would be set to on the 15A in comparison to the D8H?
Regards
Phil
Time to create page: 0.202 seconds
