- Thank you received: 22
Hello, i am Robby from italy, sorry my english is not good.
I have a D6D SA (165 HP, engine 3306 PC pre-chambers unfortunately!!!!!) 6 gears Fw, 4 Rv, and D5B SA VHP (160 HP,engine 3306 DI) 6 Fw and 5 Rev.
D6 I have to purchase used from 2007 with 11000 hrs today’s 14000 and I have rebuild the motor, gear box, reducer and repainted,
D5 I have purchased new from Brazil and have 13000 hrs I rebuild to much the transmission and bevel (two times), too much power
Both to use to make plowing
The d5 is good (no good the transmission), the d6 I have make too power,3 spacer in the fuel screew, I don’t know how much is the power now,
but the problem is the warm temperature of the water engine when use in 3 th gear under stress in plowing. Have you any suggestion?
Something simple to check is the thermostat outlet pipe--this is the cover that the top radiator hose connects to on top of the engine--Cat reduced the size of the hole to slow the water flow down thru the radiator so it could be cooled better. If the flow is too high the water is not in contact with the radiator tubes long enough to give up the heat efficiently. This smaller hole makes a big difference to the radiator efficiency.
Hello Robby,
What happens when you drop down to 2nd gear? Could you tell us what lead up to your over heating problem? What is the outside temperature?
Bob
yes, the fan is blowing air forward.Is the fan blowing air forward? or back towrds the engine? For constant pulling, ag work, the engine will run cooler if the fan is pulling the air through the fins rather pushing it.
cat@acmoc.org
- Chris R
- Jason N
