new member with a 1935 Cat 22
12 years 4 months ago #66487
by lil cat mec
one thing i have had luck with is to drill a hole and tap it in the old broken bolt then get a new smaller bolt(same size as the tap) with a nut on it and screw the bolt into the new threads, tighten the nut onto the broken bolt and use a impact gun... im not sure if it will work on either application but i thought i would mention it...
1935 CAT 22 2f4455W
CAT 951
12 years 4 months ago #66508
by zootownjeepguy
The best method I've found for removing broken bolts is to build up a blob of weld on the end of the broken bolt with a MIG welder and use a small pipe wrench to unscrew the bolt. All that heat from the welding helps loosen the threads and it works about 95% of the time.
Rich Salvaggio
D2 5U9917
The 2 most useful tools to have in your shop are a Crystal Ball...
12 years 4 months ago #66512
by ronm
If it's in cast iron, just blow it out with a torch & clean up the hole w/a tap...cuts better if you drill through it first, use a left-handed bit & it might catch & turn the bolt right out-then you don't even have to torch it...
12 years 4 months ago #66533
by lil cat mec
well i got everything on and ready to go... the motor is bolted on other than the 2 very bottom bolts... the jacks and lifts are off... and its bolted to the springs!!!
1935 CAT 22 2f4455W
CAT 951
12 years 4 months ago #66543
by lil cat mec
oh and another important thing is!!
the drain plug is GONE for the clutch housing, i would like to know size as well as thread size... or cat part number or maybe someone has one laying around???
1935 CAT 22 2f4455W
CAT 951
12 years 4 months ago #66549
by thomas84
I would leave it out. Unless your planning on running it in a swamp.
Thank you received: 37
12 years 4 months ago #66680
by brewzer
I found a pedal for your 22 if you want to return it to original. You can have it for shipping. - Wally
12 years 4 months ago #66693
by lil cat mec
tomorrow my friend and i aregoing to finish bolting everything togeather and then were going to try and adjust the clutch and if we cant get it adjusted then i will definantly take you up on your offer wally
1935 CAT 22 2f4455W
CAT 951
12 years 4 months ago #66739
by lil cat mec
i put the bearing thing upside down and the yoke is still in the same place... so i have to spend another 8+ hours working on it... so i am probably not going to work on it for a little while due to i dont have a cherry picker and the one i was using i had to take back and he is using it for another project... so i dont know whats next...... after i pull the stupid motor away from the tranny.... what should the nuts be torqued to ont the clutch??? maybe he did that wrong when he rebuilt it or??? i have no idea what to do now i am lost and not relly in any mood to work on it since it doesnt seem to do anything right!!!
1935 CAT 22 2f4455W
CAT 951
12 years 4 months ago #66741
by zootownjeepguy
Sunuva.......
Don't get too upset LCM, We've ALL done it before. Don't think of it as a mistake, think of the extra EXPERIENCE you'll gain by doing it twice!
Someday you'll look back and laugh about this.
I, personally, have LOTS of things to laugh about.
Did I ever tell you about the time I caught my hair on fire? Way back when, I had long hair past my shoulders. One day I was soldering a radiator and set the torch down. I leaned over to look for more leaks and then all the sudden it's like "What's that smell???" The first emotion was fear,...then embarrassment, ...then anger, and now I just laugh about those days when I was "more stupid".
Rich Salvaggio
D2 5U9917
Time to create page: 0.262 seconds
