new member with a 1935 Cat 22
12 years 4 months ago #66973
by zootownjeepguy
You should be looking for a parts book. Lot's of valuable information in those things.
Rich Salvaggio
D2 5U9917
The 2 most useful tools to have in your shop are a Crystal Ball...
12 years 4 months ago #66975
by lil cat mec
the only thing is im only getting the theing running and working then my grandfather is either taking it to our cabin(which i hope he does) or back to his house in Emmett Idaho(i really hope he doesnt)
1935 CAT 22 2f4455W
CAT 951
12 years 4 months ago #66981
by zootownjeepguy
Maybe you should put a "Mechanic's Lien" on the thing?
Rich Salvaggio
D2 5U9917
12 years 4 months ago #66988
by lil cat mec
how many clutch plates should be in there??? and how tight are you supposed to tighten the nuts with the springs on them???
1935 CAT 22 2f4455W
CAT 951
Thank you received: 154
12 years 4 months ago #66989
by bruce oz
hello lil cat mec ,there should be one clutch plate with a lining on each side ,the services book say to count the turns when undo them ,if it slips later you can tigthen them up ,the proplem would be if they were to tigth as the clutch would be driving all the time ,bruce oz
12 years 4 months ago #66990
by lil cat mec
ya i just took the clutch apart and realized it was one with pads on bolth sides 8/ that makes me feal kinda um stupid i guess lol... but im still not understandint why my clutch is not working... im confused..........
1935 CAT 22 2f4455W
CAT 951
12 years 4 months ago #66991
by bruce oz
hello lil cat mec ,looking back at your pic ,did you adjusted the gap in the clutch brake ,the gap in your pic is a big gap ,while its off move the brake brake out one more hole ,that towards the engine and also check the adjustment on the petal on the left side ,specs are in the operators book ,also may sure all the oil that is all over the clutch compartment is washed off ,it maybe causing the brake clutch to slip ,bruce oz
12 years 4 months ago #67008
by lil cat mec
how much does the clutch need to move in order to to fully dis engage?
1935 CAT 22 2f4455W
CAT 951
12 years 4 months ago #67010
by bruce oz
hello lil cat mec ,i would think the main clutch is ok looking at your pic but if the clutch brake is not adjusted rigth it will not stop the gear shafts from spining which causes the gears to grind as they are not sinkromesh gears,
if you havnt got the 1.5 mm gap on the clutch brake and the 12mm adjustment on the petal on the outside shafts the main clutch is disengaded before the clutch brake can aply eough pressure to stop the gears from turning , bruce oz
12 years 4 months ago #67012
by lil cat mec
the reason im asking is how little my clutch moves... here are the pics again!!!
im not touching the clutch pedal yet and the yoke is supposed to go towards the flywheel, in otherwords there is only about 1/2 an inch of movement before it hits the pressure plate!!!
another imporntant thing
the man who replaced the clutch put the wrong throwout bearing in it, it is to narrow... the inside dimater and outside are good it is just too thin so there is motion in the bearing case and on the shaft so the clutch isnt starting to disengage as soon as it should... so i am in need of the throwout bearing... im hoping i can get it from western states(our local CAT dealer and mechanic shop) am i right that the bearing number is 10+009??? thats what it looks like on my copy of the parts manual
1935 CAT 22 2f4455W
CAT 951
Time to create page: 0.301 seconds
